Old 06-26-2010, 01:59 PM
Default Re: 1978 SF restoration, my first one.....
Alright, Alright.....
This is fishbox after two heavy coats of Signature.
Yesterday the 3/8" fuel line that had been backordered was delivered after waiting for a month. Thanks to advice from Sea++ I swapped out my 1/4" pickup tube that came with the tank before the deck went in.
After reviewing everything to make sure I hadn't forgotten anything to be installed below the deck I vacuumed her out one last time. You can see the bow area has one coat of Signature on it as well as the CC further in the background.
The PVC pipe in the back right is for the raw water washdown. It almost got left out but remembered at the last minute.
We balanced the deck on the bow to get in position to drop it in.
After on last test fit I smeared Cabosil on the stringers and dropped it in place. After that cures I will go around the perimeter and add more cabosil where the deck rest on the blocking before I finish the seam with 2" tape.
Will
