Old 07-01-2010, 11:37 AM
Default Re: odd crack in a 25 Seafari
These pictures are from the port side which is the opposite side of were Connors crack is. I would have had to cut out the bottom of the starboard storage compartment to get any pictures showing the complete stringer and hull were his crack is located. I'm assuming that the hull is configured the same on both sides.
Looking down from the cabin door. The stringer appears to run directly over the step/chine that is cracked.
The crack is about 24 inches up from the bottom of the keel which puts it somewhere close to where you can see the end of the tape measure.
In the picture above note were the stringer ends. The chine/step extends about 16 inches beyond the end of the stringer however the crack is definitely inside or close to the side the stringer were the end of the tape is located.
A couple more shots looking aft
