Old 07-07-2010, 11:33 PM
Default Re: Tsunami Cabin Hatch cover
The Azek board can be heated and shaped. If you give me until next week, I can get the temp. required to shape it. We use the same material 3/4" thick and shape it quite often. You could make a form from luan panel, heat the Azek and place it on the form then, after cooling, trim it to fit. You'll have to get creative regarding your heat source because it needs to be heated all at once. Let me know if you want the info.
