Old 07-17-2010, 01:16 AM
doodlebug doodlebug is offline
Default Re: Transom Bracket - twin outboards
sounds more like a prop problem. I run my motors real high
on my bracket without breaking loose.get someone to run the boat and while running check and see where your cav plates are in the water with my 250's I had to run an inch and a half up above the water to get out of the hole. my 150's
run right on the surface also look to see if a transducer or somthing is making some problems.Also the gulf down her gets real sloppy.
1979 23 SCEPTRE TWIN 150 Opti's/GAUSE BUILT BRACKET
