Old 07-26-2010, 10:41 AM
Default Re: 1978 SF restoration, my first one.....
Thanks for the compliments guys!
Mitchman,
keep in mind that the inside of the gunnels were originally attached to the deck that formed the inner liner. I scrapped all of that when I built the new deck. If you go through some of my earlier post you can see how I cut it apart. Not sure how yours is set up but you could wind up with a void between the deck and the hull if you cut it withough removing the entire inner liner.
The exposed surface that you see is woven roven which would leave a very rough fnished surface. I've thought about fairing that surface but think that I will wind up adding about two layers of matt and sanding that down before painting. I will have to remove the top cap at least one more time when I install the supports and glass them to the hull and deck and will finish both sides at that point.
Either way I'm looking at a tremendous amount of sanding which is going to require the purchase of a new unit. Apparently my Black and Decker Cyclone has been discontinued as I can't find paper for it anymore and I don't believe my orbital is up to the challenge. Any recommendations for what to purchase would be appreciated.
Will
