Old 08-05-2010, 09:03 AM
Default Re: Can someone explain this mess?
I understand there are two bilges and two pumps for tanks on the boat at least thats what they look like but I don't quite understand what the pipe running from the back of the boat to the bottom through the hull is... Can someone please explain?
Seriously, fix the thru hull to true seacock asap. Looks to me like....blue pump pumps the cavity (bait well?) out, white fitting to plastic valve was meant to gravity fill this well, two large pumps are bilge pumps, in front is a switch, to right is trim tab pump, to left is Racor fuel filter/water seperator, in front is washdown pump
