Old 08-16-2010, 03:38 PM
Default Re: boat sunk...why? should i sell?
. . . My Seafari has three (3) bilge pumps. One 800 gph mounted right at the transom as low as possible. One 1500 gph mounted three inches higher nearby, and one 1500 gph mounted forward beneath the cabin sole. All automatic, all also seperately manually switched and wired. And when I keep it in the water for a few days, I still get up in the night and check on it.
Fr. Frank,
I've been thinking about adding a forward bilge pump also. Where did you run the discharge hose for it?
I was thinking I might tee it into the drain for the sink in the galley seat. That thru-hull is only about 8" above the waterline however, so I was thinking it might be good to put an anti-siphon loop in it, raised up near the gunnel under the deck? Denny
