Old 08-19-2010, 03:05 PM
Default Work on the V-Bunk Area
This should be my last bit of glassing (not counting the taping of the floor).
The V-bunk area before I bought the boat.
After I pulled the carpet up the gel coat was all crazed out.
I like to make notes where I know I won't forget them.
Did some heavy duty sanding.
I wanted to fill the large access holes since I would not need them and I thought they were awkward to get at.
Cut up some plastic cardboard and made it tight against the opening.
Outside and Inside View.
The layup was done from the inside. Less fairing to do and a lot less sanding.
Different sizes of glass...the first size is the same as opening and then they get larger.
When done it looks like this is the way it should be.
The next part was to lay in some backing cleats for a v bunk filler and to glass in the bow U bolt backer and the front deck lifting ring pad.
Shoot some primer to see what I have.
Happy with the results. Now to the major task of putting the floor together.
