Old 09-02-2010, 03:51 AM
Default Re: 23' CC Scupper Question
blocking in front of scuppers on the bottom of the boat are still in place...
I assume you are talking about the blocking inside the hull between the hull and liner?
If everything is still in good shape then you should be fine. Your boat should still self bail as it did before adding the bracket. I see in some pevious posts you are working on the transom in which case it would be nice to exit the scuppers out the stern above the water line...a little more work but worth it.
