Re: Interlux Perfection shelf life
I like the Interlux perfection, it is very tough and has great uv stability, and it bondsvery well,like "[censored] to a blanket". It is a Urethane chemistry, if humidified air gets to it you will have bubbles and foam issues. Also I am sure there is a tempurature at which it recomends storing ( I would bet 70-75F), heat will kill it also. I store Aurosols upside down as well as anything with a lid, if it has fillers it will also make it easier when you right side the can. BTW Alsways ask for a date or test polyester resin and gelcoat for cure, as they get old they may not fully cure and remain tacky, what a mess!
