Old 09-22-2010, 10:12 AM
Wildman Wildman is offline
Default Re: 23 CC minty green!
Started the evening off scribing and cutting my template out of 1/4in Luan. First I drilled some 1/2in holes for the alignment bolts. These holes will be transferred to the pieces of Penske board too, and I will reuse them for mounting of different things (D rings, drain plug, etc)on the transom, so I wont have to fill them.
Scribed the outside pattern,for rough size, then measured the inside of the boat to get the exact measurements
Lined up 99% the first time!
Then cut and drilled the support/clamp 2X4's
