Old 10-21-2010, 09:34 PM
76Red18 76Red18 is offline
Default Re: damp feet in an 18
Use those scuppers but a little water will still eventually find it way in. Let it drain into the well and pump it out with a 500 gph auto pump. run the hose and wiring through the drain in the well to a thru hull fitting. Seal the well drain with 5200 to keep the bilge dry. Its the only way I've been able to keep my feet dry. Mines a 76 but should be similar.
J. M. Hendrix
