Old 10-27-2010, 11:03 AM
Wildman Wildman is offline
Default Re: 23 CC minty green! Pipe Dream?
I have been bouncing between the boat and my landcruiser projects. I did get the outside all glassed up and now its time to dish out all the existing holes in the transom and patch them up too.
I got the center stringer shaped, sanded and glued down with some cabosil and resin. While I was at it, I used the thickened resin to soften the joint between the vertical on the stringer and the angle inside the hull. This should make a nice easy layup with a minimum concern for air pockets forming while I am working.
Then I ran out of resin. [] So I am going to get all the strips of 1708 cut for the layup of the stringer.
