Old 11-04-2010, 07:39 AM
Default Re: Looky what I found...
Absolutely amazing!!! Gillie, keep the original engine configuration, but you should know that Mercruiser used that same 250 ci. inline 6 GM motor to push out up to 250 hp. So if you ever need to rebuild, it's a really strong motor, and can be easily done. Most of those 250 ci motors were either 165 or 185 hp after 1967. (The 250/250 motor had twin 600 cfm 4bbl carbs, and a high-lift long-duration camshaft and required high-test gas [img]/forum/images/graemlins/tongue.gif[/img])
Fr. Frank says:
Currently without a SeaCraft
