Re: question for this new SC owner
As luck would have it...the front hatch cover is not very water tight and the hole is for draining that hatch, like when you wash the inside of the hatch you can drain the soapy water out. Also you need to put in a plug from the inside to keep the water out while under way. I do not keep anything in that hatch that can't get wet. It's always the same three steps before I launch the boat; put in the transom drain plug (duh!), put in the front hatch plug, double check the beer supply.
