Re: PERFORMANCE
If originally a single, it was probably cut for 25". If it was cut for twins and you want to run a single, you'll need a 30" shaft. Take a measurement to be sure. Measure along the transom from the top center of the transom cutaway down to the bottom of the keel. The result + or - an inch will be your answer.
