Old 11-13-2010, 07:22 PM
BigLew BigLew is offline
Default Re: salt water pickup-inboard
It may be thread directly into a thru-hull seacock and thus you may not see the threads. You did not mention if there is, infact, a seacock at the trhu-hull point. Either way, it is movable with the proper repair of the old hole(s) in the hull. (In addition to the main thru-hull hole there will be generally three hulls into the hull for screws to prevent the seacock from twisting on the thru-hull portion of the device.)
Just my two cents. Good Luck.
Plan accordingly!
