Old 11-16-2010, 07:58 PM
wildlandjeff wildlandjeff is offline
Default Re: Need help with multiple repairs to the hull.....
Sorry about that I should have said imaginary sting. All the sting trick does is prove the theory of the direction of the force that did the damage and by knowing this direction allows you to find damage that isn't easily seen. In your case the damage is pretty spectacular most of it is really an easy fix even if time consuming. The gunnel you already have a decent plan for. The damage to the liner can be fixed from just the front side. You will become a contorsionist to fix the joint between the stingers and transom The transom while harder is still pretty much straight forward. With a little beer and a lot of patience or is that a lot of beer and a little patience she can be a great boat again.
If it floats or flies I'm into it!
