Old 12-13-2010, 12:08 AM
Default Re: 1977 20ft Master Angler Restoration
Started on the transom. Alot of wet plywood up top and at the bottom. The foam had minimal water in it so I will just leave the foam alone. Sanded down all the high glass on the sides so I can blast them when I blast the hull, making it so I do not have to sand all of it.
Look at the close up of the transom. Where the stringers are and where the wood shelf was glassed in at the transom they did not even glass the transom to the hull. All the wood under there was rotten.
