Old 01-07-2011, 11:57 AM
KenB KenB is offline
Default Re: Gelcoat Versus Awlgrip versus Easypoxy - showdown.
OK, how much better is the two part (awlgrip) versus the one part (petit)? 5 foot finish? 20 foot finish? How far away do you have to be to see the difference.
I was told that using the high build primer, faring, and roll and tip would lead to a coat that was indistinguishable from awlgrip. What is the real difference?
Spraying seems to be a better approach than roll and tip, but how much does this cost if you do it on your own? Can I use the harbor freight stuff? Rent a high pressure tank/compressor?
