Old 01-09-2011, 03:37 PM
pelican pelican is offline
Default Re: Repower for 23' I/O
Pelican your right on.I put the shift interrupt switch in and mechanic said to just leave the alpha impellar in and let run rather than block it off (cools drive?).
waterpump in ?? where does the water exit ?
if you still have the water pump -the water is forced up the drive...now,there's the transfer hose-from the swivel assembly to the transom plate-where it connects to another tube-another hose connects to this,and,this feeds the engine water...my question is,where does ths water exit,in your set up ?
normally,if you're going this route,you pull the impeller out-remove the transfer hose-swivel to transom plate-install the block off piece-inside the transom assembly-this is the accepted way to do this.the hose is removed-water is forced up the,via the water intakes,on thelower unit,and,this water exits @ the swivel assembly...
