Re: Barrier Coat
Finny,
Thanks for the comment.
A 23' Seacraft has approixmately 185 sq ft. of hull surface. Call customer support at Interlux and ask them to tell you what is the "out of the can coverage" of a gallon of their product and how thick (in mils.) does the product typically setup at. Take the coverage area/gallon and your calculator, then divide the coverage area/gallon by 185 and the answer will tell you how many gallons you will need to cover the hull. If it sets up at less than 10 mils, then you will need additional product.
Ex. If you want coverage at 10 mils and it goes on at 5 mils then you will need 2 coats. (10 divided by 5 = 2)
Get the picture?
Good luck. Call with any questions- 978-363-5161.
Plan accordingly!
