Thread: 97 Merc 175 EFI
Old 03-17-2011, 09:02 PM
pelican pelican is offline
Default Re: 97 Merc 175 EFI
Losing a piston won't lock it up - a rod yes - chances are the block and crank may be shot - the LU and electronics are worth more than 200 if you want to part it out. You have the switch boxes maybe 150 - ECU - LU - stator ect. On the other hand a drop-on PH could be about 2K, check at Scream & Fly for PH's and drop-ons. You can also check for prices on the parts you have.
Just don't count on that being rebuildable
that engine has cdm's-,no switch boxes-old school mercs have switch boxes...
problem comes in with,you don't know if any of those parts are good-ask yourself the question,"would you buy a used ECU"...
