Old 03-18-2011, 04:20 PM
Default Re: Deck Drain Frustrations!
I second the last two post. Painters tape and grind the hole down to the glass. Removing the gelcoat. Cut small squares or cicles, however you grind it out, and make them bigger untils it over laps the gelcoat and then sand smooth. Usually about 4-6 layers depending how deep you grind it out.
