  #172
Old 04-14-2011, 06:01 PM
Default Moving Ahead
Just so no one thinks I'm slacking off here are some pictures of my progress in the last few weeks. No particular order to these just progress.
One of things I wanted to do before putting the floor down for good was to figure out a way to secure the engine cover to the floor without wood type screws. I did not have enough room to use T-Nuts, because a bulk head was in the way, plus when I notched the bulkhead for nylon nuts I still did not have access to it.
Here is my solution using s/s plates that were tapped for 10/24 threads.
Wood scored and 1/2 removed.
S/S Plates
Next came the floor alignment...then the epoxy and fairing compound. Now I need to tape the floor to the hull sides and do some more fairing.
After looking at the last two floor panels for a long time I decided that I needed more room around the engine.
Solution was to cut some access areas that will be hinged, so that when the engine box is opened I then open the panels.
Making the cleats for the cut out area.
Engine sitting nicely with cutouts.
Shown with cutouts opened.
The look with the engine box down
Now I feel comfortable in epoxying the last two panels down and being able to work around the engine.
Wiring for the engine should being showing up in the next few days...then I get to start it...
