Old 05-10-2011, 10:40 PM
Daltonmarineinc Daltonmarineinc is offline
Default Re: motor issues, carbs dirty maybe?
before going after carbsi would try and run it on a differnt fuel tank. this will sperate the problem,boat or motor. if it runs fine then try finding your fuel pick up in the tank.alot of times theres a screen that gets cloged up at the bottom.also check and see if there is a check valve at the tank its self. if it is the motor then yes, i would take the carbs off and clean them. make sure and buy kits before taking them off.the oring and gaskets will swell and will never go back together. good luck!
