Old 05-11-2011, 11:01 AM
abl1111 abl1111 is offline
Default Re: Windlass mount support material Ideas
Big - Got a bunch of questions:
I'm a novice with wood - what size is 6/4" ?
So you made a base of teak ? What thickness was the base teak and why did you rip it and then laminate it ? Is it stronger this way ? What did you laminate with - epoxy ?
What sealant did you use to seal the teak to the deck and the windlass to the teak ?
Did you have to buy longer studs for the windlass to go through the teak and deck ( I might have to 'cause I have that 1 1/2" under deck base )
