Thread: Scupper Help
Old 05-11-2011, 10:38 PM
GodsReel GodsReel is offline
Default Re: Scupper Help
plug em when your fishing and pull em when your running, make sure everyone in your crew understands what they r and what they do in case you take one over the transom. I had 1 76 cc with motor 2 stroke 200 on the notch . i had moved console up 5 inches and had an auxillary tank (40 gal) up front. I had very little problem with that set up. i now have a 76 cc with flotation bracket with 225 four stroke, stock console location with fuel tank as forward as possible, and a 25 gal fresh water tank forward and batteries under the console. This sits almost as well as my old one. Moving batteries helps also. Good luck you have an amzing boat and that power sounds sweet, how fast is she prob. @ 46??
