Re: Can't get lower units back on
If you don't have a second person to help . . . a ratcheting tie down strap helps so you can line up the shift shaft and the watertube . . . you should have the little pvc tube in place to guide the tube into the top of the water pump housing. Doodlebugs advice about putting the motors in forward is right on.
