Re: do i need a new fuel tank
if you have a lot of sediment, and fuel is dirty brown, inlet most likely clogs when pump is sucking, then will move clear for a while when shut off, it needs to be removed, checked and cleaned, may be easier to replace, about to do the same, also have dirty brown fuel, (rust & varnish )
Frank 1972 20' Seafari
