Re: Prop for 20' MA
First on the trailer move the motor to neutral trim - get a yeardstick or some long striaght edge and see where the Cav palte is in relation to the hull bottom - should be at least 1" above and shoiuld be a bit higher. Then start with props, you should be able to swing a 17, but your not far off
