Old 06-26-2011, 01:18 PM
Default Re: Rod Holder Placement
This is my set up and fairly typical.
You can see my flat line release clips by the halyard line at the transom. You run the line from the rod tip down through the release clips, which is great at reducing crossing and keeping baits in the water when it`s sloppy.
All 4 holders are 30*. All measurements are O.C., and from transom forward. Flat lines 52 1/2" facing rear. Rigger lines are 83 1/2" but angled out 45* pointing to halyards.
Lee`s bases are 100 1/2" and halyard hoop connection is 12" aft of base hole O.C. again.
I run Trip Ese rigger clips because they are micro adjustable and consistent. Good quality ss and nylon/delrin?
I have those Tigress 1 1/8 riggers with Lee`s elbows if you have any interest. Maybe used 4 times. Too heavy for my flexing top cap.
Do your down riggers have integrated rod holders?
What is top speed so far?
Looking great,
GFS
