Re: Help with a livewell. Need suggestions
Glass the 'box' up then glass over both sides the wood separate. Then glass the top to the box, screw the lexan to a piano hinge and hinge to box. A trick would be to router out a grove in the top so the lexan door sits flush. In that case you would want to use 3/4 or thicker plywood.
