Re: floor drains
I replaced my floor drains with the threaded thru hulls from west marine .they won't sit flush with hull as the flange surface area is a lot wider than the stock tubes ,easy modification grinder with a sandpaper disk will take no time at all to get the rite angle .u might have to grind the nut also as it is a tight fit . I didn't cut the tubes once installed there is about 1/2 of threded tube above the nut that u can mount a hose or cap them off instead of drain plugs.
