Refurbished in 2011
5.7 fuel injected 310 horsepower 80 hrs
following items are new
rop, dripless shaftseal, port and starboard 55 gallon aluminum fuel tanks with senders, fuel fill hose, and vent hose.
2 batteries with blue seas isolator switch and automatic acr charging relay, new engine gauges and throttle controls and cables as well as hynautic steering/ new steering wheel.
blue seas switch panel and fuse block
all old wiring removed new installed (marine grade)
new flush mounted simrad nse 12 inch chart plotter/ echo sounder, bsm-1 sounder module, airmar B164 1KW 50/200 khz transducer flush mounted through hull. ($4800 value)
new standard horizion matrix AIS GX 2150 VHF Reciever, (1) Digital vhf antenna.
3 rule automatic bilge pumps (2) 2000 gph,(1) 1500 new Richie compass.
bottom stripped (soda blasted) barrier coated one coat of ablative paint.
rear deck over fuel tanks recored front hatch recored all other decks solid no issues.
asking $17,000- turn key
have many photos of completed work - having trouble adding photos to post - any help will be appreciated.
631-921-9648
