Re: GIANT RUMOR
I ran really really fast all day - the item in question was located in the U shaped fuel line running from the bottom of the VST tank to the electric fuel pump. It was a small 3/4" cone shaped fuel filter looking item, that I guess would sit in the bottom of the U then get pushed up against the bottom of the pump with increassed fuel flow.
The mystery is its not called for anywhere - there is not supposed to be a filter at the bottom of my VST, they had the VST apart checking it on the pump swap - he can't figure out how he even found it. I had taken that line off earlier checking for trash and/or water in the VST on my E-10 switch over. Didn't pull the other end off or I might have found it, the screen part was completely covered with black stuff I presume was off the inside of the fuel line as it rattled around.
But it sure was nice to have it over after a year.
