Old 07-17-2011, 10:54 AM
Default Re: Need some advise...
I went through exactly what you are seeing. Older restored $ or needing resto $. I was suspect of the layup until I cut out the in deck livewell. I was very pleased with the glass work. The riggers can`t use a template and Tracker cheapened some hardware. `87 was their first year and are heavier than my `89. I had to recore all the hatches because riggers are not trained /allowed to seal screws in wood.
Keep offering your bid every week. Electronics? Pull out the end of day drain thru hull. That will tell you a lot.
Ride on mine if you wan`t.
Cheers,
GFS
Cheers,
GFS
