Re: Wiring question
Pelican,
Man - sorry for posting the picture - I guess I won't ever do that again! That coil of wire is spare fused connections for anything I might add in the future. The end of each wire in the coil is sealed. It keeps me from having to access the busbars to add equipment to spare fused terminals. Each connection on both busbars is a crimped, heat-shrunk terminal that has a sealant inside it. When heat is applied, the covering shrinks, melts the sealant and seals the entire connection. The covers are off both busbars for the picture. All terminals are coated with a milspec anti-corrosion film. The main power and ground leads are secured to the shelf (see the clip in the picture) and under the shelf all the way to the battery switch. The mounting board was encased in glass and then glassed to the inside of the console. I apologize for not making all this clear in the first posting.
