Old 09-09-2011, 09:16 AM
dbiscayne dbiscayne is offline
Default Re: Ideal Dual-Bilge set up for 20' Seafari
one pump higher than the other applies to auto pumps, if they were both std./manual pumps then both in the same area with float switches at different heights in the bilge so you're only using the smaller pump to get the little bit of water out if you happen to have a wet bilge - save your battery.
