  #28
Old 09-14-2011, 08:15 AM
pianewman pianewman is offline
Default Re: 1973 20' CC Transom woes
FINALLY, getting the boat back in the water to check new scupper repair...also to re-evaluate anti-cav plate height.
Another question: I will be installing the Hydro-Shield. Does this change the suggestion that I raise the motor 2 holes, to put the AC plate at 1 1/2" inches about the keel level (Currently AC plate is level with keel...I can't see it while on plane with moderate load). I need to get this right, as I don't have access to easily play with motor height.
73 20' CC, 150 OptiMax (HEAVY), 2 batteries in front of the console, rear baitwell.
Thanks again, folks.
1971 20' Seafari, 3.0 Merc. I/O
Peterson 1819 Aluminum single axle trailer
