Old 10-02-2011, 10:44 PM
Thumbs up
Hey Pianewman-
I finally got to look at my setup this weekend in action. With the Yamaha F100 and the size large hydroshield and a full boat (3 guys, 3 tackle boxes, a kicker, kicker fuel tank), it looks like the anti-cav plate was in fact about 0 inches above the keel, running basically dry at about 31 MPH with minimal lateral spray off the lower unit. No tape measure involved, as I was leaning over the transom at WOT.
I also have the two batteries in the center console, along with a 20 gallon topside tank. I have flotation foam where the under deck tank was.
Again, with the noticeable stern lift at WOT from (I suppose) the hydroshield and 4 blade stern lifting 12-3/4 x 17P prop. A hat tip to Fr. Frank for the suggestions on my setup.
Originally Posted by pianewman View Post
FINALLY, getting the boat back in the water to check new scupper repair...also to re-evaluate anti-cav plate height.
Another question: I will be installing the Hydro-Shield. Does this change the suggestion that I raise the motor 2 holes, to put the AC plate at 1 1/2" inches about the keel level (Currently AC plate is level with keel...I can't see it while on plane with moderate load). I need to get this right, as I don't have access to easily play with motor height.
73 20' CC, 150 OptiMax (HEAVY), 2 batteries in front of the console, rear baitwell.
Thanks again, folks.
Last edited by FishStretcher; 10-09-2011 at 12:26 AM. Reason: wrong about anti-cav plate height- see later in the thread for pix
