Old 10-19-2011, 07:38 AM
hermco hermco is offline
You can use pvc pipe coming out of the cowl that will fit inside your rigging hose. Years ago we would heat pvc with a heat gun and close the cowl on it to form it. You can also use a seperate Cable Clam for the control cables coming out of the bracket so you don't have to cut into the rigging hose. I use one for the steering hoses as well. Since you have two holes for the steering thru hull fittings in the bracket already you could remove them, use a union to connect the two hoses and put two cable clams, one for the control cables and the other for the steering hoses using the same holes enlarged.
