So the pin is free of the side pieces, and now is stuck in the cyliner eye right? You have to pull the motor off the boat to get to it. Roll it over (on a stand) so your looking at the part that would sit against the transom and start heating it. Heat, oil, Heat, oil, repeat about 200X. Then beat the Pi$$ outa it. If it still wont come out, hit it harder. We had the same problem with josh's (oilfieldman)150 earlier this year. If the motor has sat for a long time its all done. Just plan on buying a new one I would be surprised if the bores where the seals ride arnt scored up and pitted.
