Old 11-06-2011, 09:46 AM
3rdday 3rdday is offline
Default Vacuum Bagging
Is this a one time shot or production where you are doing many of the same part?
Are you going to be Resin Infusing the glass or bagging down pre wet glass?
You can use visqueen, Tacky tape, the flow media and breather can be found at a fabric shop. if you are infusing then you will have to use reinforcements that allow flow and low viscosity resins. If you are hand catalyzing and not using metermix pumps use a slow resin and or refridgerate before catalyzing to give you plenty of time to pull the resin through the whole part.
