Thread: stern drives...
Old 11-13-2011, 02:14 PM
Originally Posted by pelican View Post
that was the older bravo III drives - not an "electrolysis" problem - galvanic corrosion - electrolysis,that's hair removal...
Galvanic corrosion, right. Maybe that's why my hair is getting thinner, I have an electrolysis problem.
you need to be carefull with those older bravo drives/transom plates - the water transfer hose - there's a bushing,it will become restricted,from salt intrusion,end result is a low water/distrurbed water flow
I'm setting up my Bravo with a 1.25" through hull water pickup and a strainer. That's how it was when I got it, but I'm junking the brass ball valve and using a bronze seacock. The water pickup in the transom plate is blocked off. Does that solve the problem?
Dave
Blue Heron Boat Works
