Originally Posted by oldfielder
I suggested the flusher for the bravo because my boat has the same cooling setup and with the boAt on a trailer i now have a good system to run it in the driveway.
My 350 Mag MPI has closed cooling (including the manifolds) and came from the factory with a quick disconnect for running it on the hose.
Pelican
What is the most common cause of water ingestion, manifold failure? Do the manifolds rust out from the water jacket side, or from the exhaust passage side? Or is it riser gasket failure?
Dave
