Swinging a 3 blade 14/20 prop it takes a little while to get out of the hole and you get a little bit of a sky shot so I don't think it's the perfect prop,
a motor mounted too low will do that - you didn't mention WOT RPM, no 2 stroke should have porpoise issues - also means raise the motor. BTW I have had an 18 20 and 23 none had tabs and only occasionaly would I have wanted or needed them. Props do help as Bush added
