Old 01-01-2012, 09:58 PM
Thanks, Sean and Terry.
strick,
Thanks for checking. I guess I'm going to go with acrylic for the side cabin windows. The plastics guys are telling me it will hold up to sun exposure just as well as lexan, and it's considerably less expensive.
Dan,
Thanks again for the heads up on the engine clearance. I thought I had saved the oil pan from the other motor, but I guess not. I'll check dimensions on the new engine before I try to drop it in. It probably won't be until the end of January at the earliest. The 350 Mag MPI has an oil drain hose that pulls out through the garboard plug. Hopefully, I won't have to butcher the keel stringer to make things fit.
Dave
Blue Heron Boat Works
