Old 01-15-2012, 02:00 PM
Originally Posted by FishMagnet View Post
. . . I ve had several boats that didnt have vents and didnt have mildew in the bilge. Is there something particular to the Sea Craft hull that requires this additional ventilation?
In the factory brochures in the early 70's, SeaCraft said they didn't foam in their gas tanks because it was a bad idea, i.e., the foam would hold moisture against the tank and cause it to corrode. They said this (lack of foam) required them to ventilate the bilge (maybe a USCG requirement?) which added cost, but said ". . that's just the way it is when you're building a boat to last forever!"
Did your other boats without vents have foamed-in fuel tanks by any chance?
All I know is that my almost 40-year old SeaCraft, which was always an outboard configuration, has hull vents, and it still has the original fuel tank! Fortunately I pulled the tank right after I got the boat when it was 3 years old and found that it was resting on top of a brass nut that had evidently been dropped in the bilge during manufacture! If I hadn't done that I'm sure that the resulting galvanic corrosion would have put a big hole in the tank a couple years later! Fortunately I was able to grind out the pits and seal it with Marine Tex. I painted the whole tank with epoxy and it was in good shape when I pulled it again 6 years ago to clean it and replace hoses when I repowered. The plywood floor under the tank, which is only glassed over on the top side, was also in good shape. I think it might have rotted out by now if the bilge had not been ventilated. Bottom line: I think that the factory knew what they were doing when they installed the vents. If it was my boat, I'd keep 'em!
