Old 01-18-2012, 12:33 PM
Originally Posted by kerneltugboat View Post
...He remembered when he had his New Mercruiser MPI installed in 2000 into his 23, he constantly had oil in his bilge. He figured out it was the oil drain hose that you mentioned...
Dan,
I took a look under the motor and made some measurements. The oil drain hose is on a swivel fitting that stubs out of the bottom of the oil pan in the center. The keel stringer is about 1/4" too high for it to clear. I'll trim the stringer down and re-glass it before I install the motor. Thanks again for the heads up.
Dave
Blue Heron Boat Works
